Dreamweaver CC 2018 won't work with my E-Cart
Thread begun 7/07/2018 8:12 pm by Supreme Geek | Last modified 8/30/2018 8:38 am by Ray Borduin | 3179 views | 6 replies |
Supreme Geek
I have installed the CC extension according to your help files. I've tried to locate the "Deprecated_ServerBehaviorsPanel.zxp." It doesn't exist on my computer at all. Nor does the folder that is supposed to contain this file. I even did a search to find the file to no avail. So, what do I need to do to get my Dreamweaver CC 2018 E-Cart working like it did in Dreamweaver CS6? My boss is really on me to get some items on the store. I can't do so unless I have the E-Cart tools!
Help!
Thanks...
If you install the latest version of eCart it will include the missing server behaviors.
Supreme Geek
Hey Ray,
Do I need to upgrade to version 6? I have version 5. I tried installing the one that it says for Dreamweaver CC and all I have is the "Behaviors" panel with stuff for mouse over and such. On the "Insert" tab I have E-cart functions for adding a button or editing my cart and stuff like that. Thanks in advance!
Dale
You can install our Free Tools extension. That should have the server behaviors panel with it as well. You would have to upgrade eCart versions to get it with your eCart installation. You may need to upgrade eCart versions to work with the latest version of CC in general.
Supreme Geek
Good day Ray. I purchased E-Cart 6 this morning. I tried to install it with the Dreamweaver Extension program to no avail. Then I tried to install it with "DMX-Zone" and got the message that it wasn't compatible with Dreamweaver CC 64 bit. So, I'm a bit miffed on how I'm supposed to install E-Cart 6. Also, do I need to uninstall E-Cart 5? DMX-Zone let me install it. Are the files for the store that I created going to be there when I switch to E-Cart 6 if I have to uninstall E-Cart 5. As always, thanks in advance!
Dale
Are you sure you downloaded the correct version? It shouldn't give a 64 bit error. I just downloaded and installed and it didn't give me that error. Make sure you are installing: WAeCart_612.zxp
Me
This post has been deleted.
