recordset value not showing.. Bug?
Thread begun 6/26/2018 2:40 pm by Steve | Last modified 6/26/2018 3:22 pm by Ray Borduin | 887 views | 1 replies |
Steve
Have an odd case where a query is not showing it's value when echoed. Other recordset values work but this one shows nothing.
Maybe the way the MySQL query is handled?
This query is returned using <?php echo $Tomorrow->debugSQL(); ?>
SELECT `event_date` FROM `calendar_events` WHERE `event_date` >= NOW() ORDER BY `event_date` ASC LIMIT 1
<?php echo($Tomorrow->getColumnVal("event_date")); ?>
If I can pull a result in PHPmyAdmin it should work on the page level so a bit confused...
Steve
Problem found. Maybe this should be addressed in the MySQL visual query designer?
I created my query in PhpMyAdmin and tested to confirm it worked.
Next my DW query was created and I cut n paste the same query which created the recordset without issue... BUT this create the LIMIT 1 twice since it is also in the WA_MySQLi_RS function.
Reopening the Query Editor and closing it sorted the problem and now things work as expected.
