Best practices - PHP rtrim() on Looping Recordset
Thread begun 6/15/2018 7:46 am by Steve | Last modified 12/11/2019 5:37 pm by Ray Borduin | 3628 views | 7 replies |
Steve
What would be the best means to trim the last comma from a looping recordset result?
One option is putting the looped results in an array and then using the php rtrim() function.
echo rtrim($r_results, ',');
Would this be the best way or are there other options?
Current Code:
// Multiple Markers
var markers = [
$wa_startindex = 0;
while(!$Locations->atEnd()) {
$wa_startindex = $Locations->Index;
['<?php echo($Locations->getColumnVal("pageName")); ?>',<?php echo($Locations->getColumnVal("lat")); ?>,<?php echo($Locations->getColumnVal("lng")); ?>],
$Locations->moveNext();
$Locations->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
The goal being to get rid of that last comma after a group of bracketed results (......tions->getColumnVal("lng")); ?>],)
// Multiple Markers
    var markers = [
$wa_startindex
0;
while(!
$wa_startindex $Locations->Index;
        ['<?php echo($Locations->Results[$wa_startindex]["pageName"]); ?>',<?php echo($Locations->Results[$wa_startindex]["lat"]); ?>,<?php echo($Locations->Results[$wa_startindex]["lng"]); ?>]<?php echo($Locations->atEnd()?"":","); ?>
unset(
$wa_repeatcount);
Steve
What is this crazy magic you're sewing Ray? :-)
public function atEnd() {
return $this->Index == sizeof($this->Results);
Am I correct in seeing this function (atEnd) being used to determine the end of an iterated array?
Next a "Ternary Operator" / comparison is done between a comma and the replacement ""
https://en.wikipedia.org/wiki/%3F:
Thats pretty cool thanks!!
Maybe at some point, (when your not busy) it would be worth while to create a Cheat Sheet that has all the customer WA functions and how they work?
When I'm not busy ;)
Steve
Hello,
Any reason this would not work? Any changes to rsobj.php? I am using version 2.32
$wa_startindex = 0;
while(!$rsStates->atEnd()) {
$wa_startindex = $rsStates->Index;
<?php echo($rsStates->getColumnVal("state_abv")); ?><?php echo($rsStates->atEnd()?"":","); ?>
$rsStates->moveNext();
$rsStates->moveFirst(); //return RS to first record
I've checked the recordset count for any hidden values but that is not the case.
atEnd() won't be true until after the move next.
I think this code will do what you want:
        $wa_startindex
0;
        while(!
$wa_startindex $rsStates->Index;
           <?php echo($rsStates->Index == 0?"":","); ?><?php echo($rsStates->getColumnVal("state_abv")); ?>
          $rsStates
->moveNext();
        unset(
$wa_repeatcount);
Steve
Thanks Ray, that works well!
Not sure how the first record shown has a comma "after" it, when this logic is showing the conditional comma code "before" the echoing of "state_abv".
It skips the first one. That way it is effectively adding it after the one before if there is one before.
