Tick Box
Thread begun 6/13/2018 1:18 pm by john70964 | Last modified 6/22/2018 9:33 am by Ray Borduin | 4249 views | 10 replies |
john70964
Tick Box
Hi Ray
Would you please have a look at a form I have been trying to get working but cannot.
I was able to get a tick box working and validating correctly on a new simplified form but when I try to update
an existing form it does not seem to work.
I did get the tick box working and updating the database but have lost that again.
I am attaching more details in the private message.
Try updating this line:
GetSQLValueString($_POST['ContactPermission'], "tinyint"),
GetSQLValueString($_POST['ContactPermission'], "int", "1", "0"),
john70964
Thanks Ray,
On localhost when I place
GetSQLValueString(isset($_POST['ContactPermission'], "int", "1", "0"),
I get a syntax error on lines 96 and 97
If I remove (isset the sytax error goes away.
However the ContactPermission field in the database remains at Null.
Yes, that part should not have been there. I've updated the code above. I feel like it should be working at this point.... however let's try this one more variation:
GetSQLValueString(isset($_POST['ContactPermission'])?"1":"0", "int"),
I see you are using the standard Dreamweaver update server behavior. Another option is to update to the webassist version which is much more versatile.
john70964
Thanks Ray
That gave the same result, Null.
Re: I see you are using the standard Dreamweaver update server behavior. Another option is to update to the Webassist version which is much more versatile.
In creating Recordsets I usually Select Server Behaviours + and then click on Recordset at the top of the list.
Perhaps I should be using + Webassist > Mysqli Recordset. If so is it OK to have web pages on a site some using MySql and some using MySqli ?
You can use both mySQL and MySQLi on the same site or even the same page without any issues. I looked at the code on the live page and it is still the original version. Are you sure you were updating and testing the correct file?
john70964
Sorry Ray
I have just been uploading to localhost but I have updated the remote server just now.
I see you have your fields in the wrong order. You have MeasureInBeam, ContactPermission in your insert statement, but when you list the values you have:
GetSQLValueString($_POST['Beam_Measure'], "text"));
That needs to be consistent. This is why hand editing is usually the wrong choice when you have Server Behaviors you can update ;)
The easiest solution is to switch the order of the columns above. I've done that and uploaded the page so you can see and compare.
john70964
Hello Ray,
Thank you for your much appreciated help in getting the form working.
Trying to understand more fully what is going on on this form, I opened the
SB Insert Record behaviour (as you suggested I believe) and was asked to install MySqli.
I think I may have worked with MySqli previously on this page.
I received a Dreamweaver message attached.
The elements were set to None.
I wondered if I should delete those elements as they have been deleted on the form already some time ago
but could not see how this would be carried out?
Picture attached
Later:
Hello Ray
I am getting there and learning many things!
I have one more item that does not seem to behave as expected.
The field Description1
listed under Boat information is being completed correctly, but the
validation 'Show if' shows in spite of this when the page is shown in a browser.
The code looks correct to me...
I notice that I have two Binding groups
1 WA Validated Entries (boats_InsertCopy2.php)
2 WA Validated Entries (boats_Insert.php)
Maybe this is because I copied boats_InsertCopy2.php to avoid overwriting the original?
Maybe one file should be deleted?
I have uploaded the files please see the PM.
Many thanks
John
You had copied and pasted the line for the validation and didn't increment the identifier. That means both the boat information and terms checkbox were using the same validation. It was probably the terms validation that was failing causing both messages to show. I updated the validation code to address the issue.
