How do I update the Paypal option to meet the new PayPal Protocol Standrards going into effect June 30, 2018?
Thread begun 6/11/2018 2:53 pm by birdscreen398247 | Last modified 6/12/2018 8:41 am by Ray Borduin | 653 views | 1 replies |
birdscreen398247
I am getting notices from PayPal that the protocol I am using will no longer work after June 30.
I am using the built-in PayPal connection in eCart.
Is there an update to fix this problem?
You don't have to update your code. You probably have to update your server.
Use this code on a new blank page:
$ch
curl_init('https://www.howsmyssl.com/a/check');
curl_setopt($chCURLOPT_RETURNTRANSFERtrue);
$data curl_exec($ch);
curl_close($ch);
$json json_decode($data);
echo
$json->tls_version;
It will tell you the TLS version your site has installed and it if isn't 1.2 or greater, then contact your hosting provider and have them update it for you.
