users_login.php
Thread begun 6/11/2018 7:25 am by Jamie | Last modified 6/11/2018 1:18 pm by Ray Borduin | 8956 views | 8 replies |
Jamie
users_login.php
Hey Ray
On the users_login.php page, have updated the SA authenticate login
if(isset($_POST["LogIN"]) || isset($_POST["LogIN_x"])){
$WA_Auth_Parameter = array(
"connection" => $PowerCMSConnection,
"database" => $database_PowerCMSConnection,
"tableName" => "pcms2_users",
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["userName"]))?$_POST["userName"]:"") ."".$WA_Auth_Separator."".((isset($_POST["Password"]))?$_POST["Password"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserGroupID".$WA_Auth_Separator."UserFirstName".$WA_Auth_Separator."UserLastName".$WA_Auth_Separator."UserEmail"),
"sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserGroupID".$WA_Auth_Separator."UserFirstName".$WA_Auth_Separator."UserLastName".$WA_Auth_Separator."UserEmail"),
"successRedirect" => "",
"failRedirect" => "",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
to
$Authenticate = new WA_MySQLi_Auth($DBConnection);
$Authenticate->Action = "authenticate";
$Authenticate->Trigger = (isset($_POST["LogIN"]) || isset($_POST["LogIN_x"]));
$Authenticate->Name = "LoggedIn";
$Authenticate->Table = "pcms2_users";
$Authenticate->addFilter("UserEmail", "=", "s", "".((isset($_POST["userName"]))?$_POST["userName"]:"") ."");
$Authenticate->addFilter("UserPassword", "=", "s", "".((isset($_POST["Password"]))?$_POST["Password"]:"") ."");
$Authenticate->storeResult("UserID", "UserID");
$Authenticate->storeResult("UserGroupID", "UserGroupID");
$Authenticate->storeResult("UserFirstName", "UserFirstName");
$Authenticate->storeResult("UserLastName", "UserLastName");
$Authenticate->storeResult("UserEmail", "UserEmail");
$Authenticate->AutoReturn = false;
$SuccessRedirect = "";
$FailedRedirect = "";
if (function_exists("rel2abs")) $SuccessRedirect = $SuccessRedirect?rel2abs($SuccessRedirect,dirname(__FILE__)):"";
if (function_exists("rel2abs")) $FailedRedirect = $FailedRedirect?rel2abs($FailedRedirect,dirname(__FILE__)):"";
$Authenticate->SuccessRedirect = $SuccessRedirect;
$Authenticate->FailRedirect = $FailedRedirect;
$Authenticate->execute();
the resulting page is blank and the error is
Warning: require_once(../webassist/mysqli/authentication.php): failed to open stream: No such file or directory in /home/motle7bk/public_html/clients/template/admin_cms/users_login.php on line 21
Fatal error: require_once(): Failed opening required '../webassist/mysqli/authentication.php' (include_path='.:/opt/alt/php54/usr/share/pear:/opt/alt/php54/usr/share/php') in /home/motle7bk/public_html/clients/template/admin_cms/users_login.php on line 21
have checked the webassist/mysqli/ folder and authentication.php has not been created
Just create a blank page and apply the server behavior... maybe even just open and re-apply the server behavior and it should create that file so you can upload it. My guess is that it isn't created when updating from the old version.
Jamie
'fraid thats not worked. set up a new page without it on and authentication.php was not created.
using latest posted version of DA and cc2015
Odd... I just created a blank page and applied the authentication server behavior from MySQLi and the file was created. Which server behavior did you apply? Message me in Skype and we can do a screen share to look into it more.
Jamie
hve tried accessing SA > Authenticate User from both main tool bar as well as the server behaviours area
Use the server behavior: Webassist->MysQLi->User Authentication->MySQLi Log In User
Jamie
ok thats done it, thank you. Only problem is that as super admin am no longer able to login in - just keeps redirecting to itself
have attached the page
EDIT...it seems to only be Super Admin as Admin and below are logging in fine
It probably has something to do with the super admin rule and the validation on the super admin landing page: settings_sections_update.php
I'd have to debug it in place to see. Maybe in our next premium support ticket.
Jamie
ok will do...will have to revert it for now
