Logon does not open its protected webpage
Thread begun 6/05/2018 6:58 am by randyrie405335 | Last modified 6/05/2018 10:19 am by Ray Borduin | 1255 views | 1 replies |
randyrie405335
re: Mac OSX v10.11.4, PHP v5.5.31, DWCS6
My logon & restricted web pages (using MySQLi server behaviors) work fine on my localhost but not on my host site (PHP 5.6.27). So I know that I've configured the pages' behaviors correctly I am enclosing screen shots showing their configurations. Please let me know if you see any error setting them up? Also, if they are configured properly, do you have any ideas why the entered logon credentials simply disappear when the submit button is clicked?
If it works on localhost and not the live that implies it is a server configuration issue. Most likely session variables aren't being stored properly.
The solution is usually to contact your hosting provider and make sure the session_save_path setting in your php.ini file is set to a directory that exists and has the proper permissions.
To test if it is a general session storage issue, create two pages. One that sets a session variable like:
@session_start();
$_SESSION["works"] = "true";
Then create the second page to write the session variable with:
@session_start();
die(
$_SESSION["works"]);
If you visit the first page and then the second... the second page should say "true". If it is blank or shows an error that means your session_save_path is wrong and most likely your hosting provider will have to fix it for you.
