Converting an older WA Google Maps Pro file to be MySqli and PHP 7 compatible.
Thread begun 6/05/2018 6:47 am by astrostrom | Last modified 6/11/2018 12:31 pm by Ray Borduin | 2342 views | 7 replies |
astrostrom
Converting the Recordset to MySqli does not seem to be a problem.
However, the "wagmp_map_1.php" file I am using which retrieves location info from a database and insets it into a dynamically generated Google Map needs to be updated.
Basically, to make this work I need to update code such as:
<?php echo str_replace("'", "\'", "".$row_rsAgenda['address_street'] .""); ?>
Is there a MySQli equivalent to the above?
And, would the Google Maps Pro extension in Design Extender generate PHP 7 compatible code?
Thanks for any advice.
is:
$rsAgenda->getColumnVal('address_street')
astrostrom
Thanks Ray
I thought the "echo str_replace" part may have also changed. I still have some other issues in order to make this work which I am trying to sort out.
However, while testing I got a notice from Google informing me that on June 16, 2018 they will start charging for using the Google Map API. Do you know anything about this and how it may affect the Google Map app?
More info: https://cloud.google.com/maps-platform/
Pricing: https://cloud.google.com/maps-platform/pricing/
The API key will be required and you will have to have a credit card associated with your account. Other than that there shouldn't be any effect.
astrostrom
Hi Ray - I am still having trouble converting my Google Map to MySqli. I have added my code in a PM.
And yes, I have a new API. Thanks for having a look.
This looks correct to me. Do you have a url where I can see it broken?
astrostrom
Old code working here:
http://www.swissart.ch/en/agenda_aargau_solothurn_region.php
(Section Museums - Google Map)
New code not working here:
http://www.swissart.ch/fr/agenda_aargau_solothurn_region.php
Attached is my new intermediate page "google_agenda_map_2.php " that calls the file:
The issue appears to be the map function name being out of sync with the code.
function wagmp_map_1() {
should be:
function wagmp_map_2() {
