Update/Inserts seems to have a problem
I can't ever seem to get the update/inserts to work. I went in and manually binded the form fields to each and still the page is blank. Edited all the recordsets and all seems to be ok...
Actually I'm kind of at a lose as I removed all the database stuff and the page still comes up blank...
The insert record server behavior must have been updated wrong when converting from a previous version. I had to delete and re-set the bindings. The page seems to load now.
