_mmServerScripts error
Thread begun 6/02/2018 2:33 pm by kg_nsa395746 | Last modified 6/05/2018 8:59 am by Ray Borduin | 1976 views | 6 replies |
kg_nsa395746
Ray, I am receiving an error when attempting to connect to my database in Power CMS. (see attached image). I've deleted the _mmServerScripts error that is mentioned in the error message but that isn't solving the problem. Can you help me resolve the issue?
This is usually an issue with the site definition in Dreamweaver. Probably the testing server isn't defined properly or the site url is wrong.
kg_nsa395746
I have reviewed all my settings. The remote and testing servers in Dreamweaver site definition test successfully. The database settings in Power CMS match those defined in the PowerCMSConnection.php file.
I have added the Database and Server Behaviors extension.
When I check the WA Database, I get the error "no tables found".
See attachment.
Can you export your site definition and send it to me? I can use that to reproduce the issue and debug it from there. Most likely the site url in your testing server definition is wrong.
kg_nsa395746
See attachment for site definition. Let me know if you need anything else. Thanks Ray.
Your website has an automatic redirect from http:// to https:// but your Web URL in your testing site definition in Dreamweaver uses http://
If you change it to https:// that should fix the problem.
kg_nsa395746
Well, that is certainly a "duh" moment. Thanks for catching the error for me, Ray. Power CMS is working now!
