Sort again
Thread begun 5/31/2018 11:39 am by vernon webb | Last modified 5/31/2018 1:00 pm by Ray Borduin | 1637 views | 4 replies |
vernon webb
Sort again
This is a different page with the sort setup on it. When I click a column header the page refreshes and then only one record is now being displayed on the page
vernon webb
I've actually found the problem it's throwing an error on line 555 which simply doesn't make sense sense it's a simply echo from the recordset...
The recordset is in an IF statement, so it doesn't always exist. I've updated your code so that the IF statement includes the code that writes the value so that it won't try to reference a recordset that hasn't been created.
vernon webb
OK it's working but the sort isn't. Feel like I'm going in circles.
You had a whole bunch of static orders set in your sort server behavior. Those should be added to the SQL statement directly so that the sort server behavior only has the dynamic sort column. I've updated that and the page works properly now.
