Change field names to sentence case in blank template
Thread begun 5/31/2018 6:01 am by mrs | Last modified 5/31/2018 11:04 am by Ray Borduin | 1192 views | 2 replies |
mrs
The UE creation widget takes the names of the database fields and strips them of underscores and replaces with spaces. I've also added a string to remove other parts of the field names within the blank template like so:
<?php echo(str_replace("_"," ",$pkey))); ?>
<?php echo(str_replace("_"," ",str_replace("fld_cu_","",$pkey))); ?>
but I'd also like to make the dynamically generated field titles appear in sentence case (rather than lowercase as I'd named them in the database). How do I make the above do that?
Thanks.
ucfirst() function will make the first character upper case like:
<?php echo(ucfirst(str_replace("_"," ",str_replace("fld_cu_","",$pkey)))); ?>
mrs
Thanks Ray, I'd just figured it out myself and was about to let you know... but you beat me to it!
I've been working on it all afternoon though :D
