Cart Session not generated
Thread begun 5/30/2018 2:03 am by info4753 | Last modified 5/30/2018 1:08 pm by Ray Borduin | 2050 views | 4 replies |
info4753
Hi Ray it looks like $WA_sessionname ="Bestellnummer" is not being generated by the cart. Also the detailOrder is just updating the last record, not inserting a new one. I've attached the two files. Thanks for any help.
This might be an issue with the Table definition. Does your orders table have an OrderID column that is defined as a unique key with an auto-number attribute? That is a necessary requirement and would cause the issues you describe.
info4753
Hi Ray. The table definition is correct. It looks like the $WA_sessionname ="Bestellnummer" is not being generated at all.
Try changing this line:
$_SESSION[$WA_sessionName] = mysql_insert_id();
$_SESSION[$WA_sessionName] = mysql_insert_id($WA_connection);
info4753
Problem solved! Thanks a lot Ray :-)
