email not sending
Thread begun 5/29/2018 6:33 am by Jamie | Last modified 5/29/2018 7:36 am by Ray Borduin | 1557 views | 4 replies |
Jamie
email not sending
Hi Ray
The attached page ord_detail.php is a plugin on the other attached page order_details.php
On ord_detail.php there should be an email being sent which is triggered on update but although the associated column value changes, the email doesnt seem to be sending (well its not arriving)
Many thnaks
Jamie
It looks like it would work.
You could try adding this before the email close on line 50:
var_dump($Email);
die();
I see there is no subject set in the email. That could definitely effect deliver-ability.
Jamie
doesnt look like its adding the email address from the DB
Do you have a valid email address in the database? Try adding:
var_dump($WADAorders->Results);
var_dump($Email);
die();
Jamie
yep, definitley in the db
just run with your debug
["OrderEmail"]=>
string(17) "info@motley.co.uk"
EDIT. have figured it out. sorry to have been a pain
