hiding search
Thread begun 5/29/2018 6:05 am by Jamie | Last modified 5/29/2018 12:25 pm by Ray Borduin | 5198 views | 21 replies |
Jamie
hiding search
Hey Ray
How would I display this
<div class="coffee-span-12 resultsRows">
<span><strong>You searched:</strong>
<?php if($_POST["SearchContent"] != ""){ ?>
<?php echo $_POST["SearchContent"]; ?>
<?php } else { ?>
search was empty
<?php } ?>
</span>
</div>
only if the search button has been clicked on the attached page?
thanks
Jamie
You might try:
if (isset($_SESSION["WASearch_Recordset2"])) {
// show this when a filter is applied
or
if (isset($_POST["WADbSearch1"]) || isset($_POST["WADbSearch1_x"])) {
The problem with the second one is that it wouldn't show after navigating to the next page of results.
Jamie
thanks mate - how would I set up the first one?
Just put the code on the page manually wrapping your html that you want showing conditionally.
Jamie
sorry, understand that bit - just not sure where the WASearch_Recordset2 session comes from?
That session variable is automatically set by the search server behavior whenever a search is performed. That is how the search is maintained from page to page when navigating through the recordset.
Jamie
ah right...I'm afraid that this doesnt work. It doesnt show the message at all
Is there a URL where I can take a look?
Jamie
sure, am in the final stages of the CMS that youve helped me with a coupe of times.
If you login with the usual and head to 'Content' and then 'Blog' - its the blog_results.php page
Your recordset is named: WADAblog
You had to replace that bit in the code chunk, so it should have been:
if (isset($_SESSION["WASearch_WADAblog"])) {
