Storing session or cookie
Thread begun 5/26/2018 8:24 am by Kumel | Last modified 7/12/2018 8:48 am by Ray Borduin | 4600 views | 9 replies |
Kumel
I have to types of users.
1 - Logged in user.
2 - Guest.
Login user has a UserID Session to be used if any record is inserted.
In such case for Guest, I would like to store data like inserting a record using cookie.
Example:
Table named "Data" contains : DataID DataUserID DataName
Currently if logged in User insert a record into Data table we are storing session ID of user.
But in case of guest what needs to be done.
I'd probably just insert a 0 for guest users. I'm not sure I understand your question.
Kumel
I thought zero itself for guest users but how do we then know individual records of that user?
Let's say a user, add products into "Cart". "Cart" is a table, it contains: CartID, CartProductID, CartUserID, CartPrice.
Now when a user adds a record CartUserID is taken from session if exists else it takes 0, as guest user.
But how can each guest user view his cart ?
Well you couldn't. You would need a way to identify the user. I need to know the full description of what you are trying to do before I can advise you on how to accomplish it.
You could use a SessionID instead of UserID in the Cart table to keep identification of the guest cart items.
Kumel
I m creating an eCommerce kinda website. Users can add products to Cart. This is just like I created tables as Cart, Products, Users.
For Storing UserID in Cart it's storing using SESSION['SecurityAssist_UserID']
The user doesn't really have to log in to add products to the cart.
The user should be able to add products to the cart irrespective of user login. The individual guest user can view their own cart.
The session_id() value is unique to each browsing session. You could use that instead of the UserID from the session to work for both logged in users and guest users.
Kumel
oh ok. I seem to get the point. So how is it done? random session values on page load? How do we do this?
The session id is automatically created by the php server as long as the session has started. You can start the session with code on the top of the page like:
<?php @session_start(); ?>
Then you can use the id at any time with: <?php echo(session_id()); ?>
Kumel
How can i use this same login in where clause?
My Codes:
$session = ''.session_id().'';
$query_Cart = "SELECT * FROM Cart WHERE CartSessionID = '.$session.'";
Nothing is appearing even after data exist.
That should work. Did you add @session_start(); above it somewhere on the page?
