More Plugins
Thread begun 5/25/2018 10:57 am by vernon webb | Last modified 6/01/2018 10:43 am by Ray Borduin | 1070 views | 3 replies |
vernon webb
More Plugins
Ok so I have finally gotten one to work. But now the next plugin in based on the plugin that is working. When I want to select the tag to add the behavior I cannot select the tag, so how do I get multiple ones to work?
You could temporarily add a div with the same ID to the plugin page and then delete it after you have applied the behavior.
vernon webb
Very confusing and I didn't get it to work.
You have a recordset on your clientStatus_contact.php plugin with:
SELECT username FROM users WHERE users.active = ?
But you are passing in the customers_id from the customers table. I don't see a way to filter that list from the customers_id since there doesn't seem to be a column in your users table that matches the customers_id. What column did you want to use as the filter? Are you sure it is based on the Client field?
