Frustration level at ALL TIME HIGH with this.
Thread begun 5/25/2018 8:29 am by Web Manager | Last modified 4/21/2022 10:36 am by Ray Borduin | 5349 views | 14 replies |
Web Manager
We have
uninstalled Dreamweaver CC -
reinstalled Dreamweaver CC.
Uninstalled Databridge Beta -
reinstalled Databridge Beta
more that 10 times now and still getting errors - have not been able to generate anything useful in the way of updating records since buying you extension.
Here are the errors we are getting now :
I realize there is a learning curve using new products but 3 weeks and still unable to create a simple update form not what I would expect.
This is likely an issue with your Dreamweaver site definition and not the page itself. Are you using a remote server or local testing server? It could be a server configuration issue as well. Can you export your site definition and send it to me? I can try to reproduce the problem that way and it might allow me to tell you the cause.
Web Manager
Really would like to get this extension to work
I imported your site definition and everything seems to be working for me. I'll need to set up a screen sharing session in order to debug it on your computer. Please post a US phone number or Skype contact information and I'll call you to do screen sharing and make sure everything works properly.
Please reinstall the latest version of the extension before we meet to make sure we are both using the same code base.
Web Manager
skype
I've added you to my Skype contacts. Please contact me there and we can schedule a time to look into your issue.
Web Manager
Not having much luck still
http://reuniontickets.com/create/Group_Accounts_update.php?group_acct_id=8&state=MA
Also if I just want to build a simple update from what should I be using ? The Datassist pages seems limited especially as it relates to select for drop down menu (no ability to filter the recordset
Your include files were in the wrong order. The rsobject.js file defines the WA_RecordsetObject class, and it needs to be above any references to it.
Web Manager
How do you edit the form once created in the dataassist form area - I want to change a field from a text field to a hidden field
They can be edited with dreamweaver. Just change type="text" to type="hidden" for that form element and remove any other html you don't need.
