mysql_insert_id();
Thread begun 5/23/2018 3:04 pm by vernon webb | Last modified 5/24/2018 8:00 am by Ray Borduin | 1842 views | 3 replies |
vernon webb
mysql_insert_id();
When I wanted to get the last inserted record from a database I would enter the following:
$_SESSION['svClinetID'] = mysql_insert_id();
I am trying to do that with mysqli and it doesn't seem to work
$_SESSION['svClinetID'] = mysqli_insert_id($connIO_i);
There is a line in the insert code that will automatically save the insert id into the session. Line 47 you have:
$InsertQuery->saveInSession("customersID");
Just update that to:
$InsertQuery->saveInSession("svClinetID");
That will save the insert id into the session as $_SESSION['svClinetID']
You don't have to do this manually. (Delete the code you added on lines 27-30. Even if it had the correct syntax it wouldn't work because it is above the insert code. You can't get the insert id before the insert takes place.
vernon webb
I have done this and tried to redirect the the next page with that session as a URL variable (line 46) and tried to echo that variable to the next screen with no success. FYI, the database is setup for testing so submitting test values doesn't not matter.
Since you set the redirect url before the insert, the session variable hasn't been saved yet. To allow for this there is a special placeholder you can use in the redirect. Just set it to:
insert_client_contact.php?ID=[InsertID]
and that should automatically add the insertid to the redirect without having to save it at all.
