Login Issue
Thread begun 5/23/2018 7:08 am by vernon webb | Last modified 5/23/2018 9:05 am by Ray Borduin | 2441 views | 3 replies |
vernon webb
Login Issue
I have new login pages created (forgive me if I posted this already as I thought I did but I can't find it) which work and allow me to log in. It redirects to the main.php page and after logging it I have the username session value echoed to the page, however it is displaying the record id and not the user name. When I check the bindings using DataBridge it says that it is indeed binded to the user name.
The username is being stored properly.
You were using code to display it:
echo $_SESSION['SecurityAssist_username'] > "<br />";
Which is displaying whether the value is greater than "<br />", which is doing an alphanumeric comparison and returning "1" for true.
Updating that line to:
echo $_SESSION['SecurityAssist_username'] . "<br />";
displays the username with the br tag appended.
Yes, you can just change the save as field name to whatever you want either in the code on the login page or through the UI.
vernon webb
If I use the code on line 9 it thinks I'm not logged in.
That is because you have changed the session variable name and didn't update the security rule to match. Whatever you update the session variable name to has to be updated in the rule as well.
You can manually update that in the file: webassist/security_assist/helpergroupsrulesphp.php on lines 8 and 32.
