Updates
Thread begun 5/22/2018 9:09 am by vernon webb | Last modified 5/24/2018 7:22 am by Ray Borduin | 3685 views | 12 replies |
vernon webb
Updates
Should I use the edit function server behavior to update the updates? Or delete and recreate?
I'd need more context to answer this question.
vernon webb
An old update already exist. It is giving me the option to edit it, however it is mysql. Should I edit or delete and recreate?
You should be able to edit it and it will update properly... but either would work. Just make sure there is nothing else in the code block because the entire block will get overwritten.
vernon webb
I get a message that says, "Could not find selected tag node."
vernon webb
I edited it the update using the new server behavior and am now getting 500 Internal Server Error:
vernon webb
I found the error in the error logs. It's below.
This line:
UpdateQuery->bindColumn("sun", "s", "GetSQLValueString(isset($_POST['C1']) ? "true" : "", "defined","1","0")", "WA_BLANK");
should be:
UpdateQuery->bindColumn("sun", "s", "". (isset($_POST['C1'])?"1":"0") ."", "WA_BLANK");
vernon webb
I've gotten everything to work on this page but the update. I edited it with the newer server behavior and still no cigar
vernon webb
The above on and this one as well. I was pretty sure you said I wouldn't have to do anything if I downloaded the includes that you mentioned, I did but still seem to be having issues with all of my inserts and updates. Beside the link above the link below is not working either.
