Import preset from previous version of DA
Thread begun 5/21/2018 9:37 am by mrs | Last modified 8/06/2018 10:47 am by Ray Borduin | 2238 views | 4 replies |
mrs
I'm trying to import presets from the pre-MySQLi version of DA, but I am being presented with an error of: 'The file you selected is not a valid Data Bridge Design preset.'
I have tried this with my previous DA presets, and I have just tested it by exporting the current Beta preset and then trying to reimport it. I got the same message.
Is there a way to edit the presets by hand rather than rely on the import of the preset manager?
Yes. You can copy and paste the presets manually from the configuration folder from your old site to the new one.
The presets are in the folder:
Configuration/Shared/WebAssist/DataAssist/XML
You could copy that entire folder from your old installation and then paste it into your new one. I'd skip existing files in case there have been updates, but that would add back any missing ones.
mrs
Thanks Ray.
software.current355386
came across this, I would like to achieve
copy ALL presets from dw cs 6 on iMac to dw cc2018 on iMac pro.. using dw6 expot not an option as it keeps crashing
looked for the directory u mentioned could u be more specific please many thanks
on beta release on both systems
mrs
Here you go, a screenshot of the path for you. You will find any saved presets for any extension saved there.
Just in case you don't know, in finder, hold down the alt key, click on the 'Go' menu and the hidden library folder should appear there. Let go of the alt key and it disappears.
