500 Error
Thread begun 5/21/2018 6:35 am by vernon webb | Last modified 5/21/2018 12:09 pm by Ray Borduin | 1024 views | 1 replies |
vernon webb
500 Error
When I open this page I get a 500 error. The recordsets have been updated, but when I try to update the "update record" in the behaviors panel I get a number of error. Again I can most likely delete this and create a new update which may solve the problem, but thought you might want to see it.
You had this line:
<?php if (isset($rsORDER->getColumnVal('updated_date'))) { ?>
that isn't valid... it should just be:
<?php if ($rsORDER->getColumnVal('updated_date')) { ?>
That is probably an issue with the update from the old recordset syntax. I think that would have been valid when referring to a row from a standard recordset.
