Forgot Password - @@ConnectionPath@@
Thread begun 5/20/2018 7:00 am by B Tonkin | Last modified 5/21/2018 5:45 pm by Ray Borduin | 1318 views | 2 replies |
B Tonkin
Testing out DataBridge and using it to 'Create Security Pages'. Noticed an issue so I'm reporting it in. Hope this is the right process.
It mostly works (creates the login, logout, registration and user update pages) however I thought I'd better test out the Forgot Password process. Starts out okay, but on submission it reports the following error ...
Fatal error: Uncaught Error: Class 'WA_Email' not found in /home/ahjsaas1/public_html/reports/webassist/security_assist/helper_php.php:176 Stack trace: #0 /home/ahjsaas1/public_html/reports/webassist/security_assist/helper_php.php(300): WA_Auth_SendEmail(Array, Array) #1 /home/ahjsaas1/public_html/reports/webassist/security_assist/helper_php.php(323): WA_Auth_ForgotPassword(Array) #2 /home/ahjsaas1/public_html/reports/forgotpassword.php(100): WA_Auth_ForgotEncryptedPassword(Array) #3 {main} thrown in /home/ahjsaas1/public_html/reports/webassist/security_assist/helper_php.php on line 176
Not sure exactly what the issue is, but on line 4 of the forgot password.php page I noticed the following ...
require_once('@@ConnectionPath@@');
I've let Dreamweaver go through the creation process a few times now but it always seems to keep that line in there when it creates the forgotpassword page.
Thoughts? What should it have in there?
On MacOS using DW CC 2018. Latest version.
That should be the path to your connection file... like: ../Connections/yourconnection.php
The other message is from missing email include files. They probably aren't getting copied over. You can just create a new blank page and apply the "Send email message" server behavior to get the files created and then upload the webassist/email server behavior to fix that one.
I'll look into these for fixes in the next update. Thanks for bringing them to my attention.
B Tonkin
Thanks for that response, Ray. The Database Connection file was included on the next line so I deleted the other one.
Created the email files, uploaded them and then the whole login system worked beautifully.
