Odd recordset results
Thread begun 5/18/2018 11:04 am by vernon webb | Last modified 5/21/2018 11:55 am by Ray Borduin | 4368 views | 11 replies |
vernon webb
I know this is kind of outside the WebAssist ext but hoping you could help me. I had this code working with the old version but after the recordset was changed it broke so I recreated a fake area I wanted repeated and wrapped it around this code. It basically writes the results returned to a csv file, but for some reason it writes the same record over and over:
$fp = fopen($fileName, "w");
fwrite($fp,"Pub Name,Advertiser,Title,Insert Date,Our IO #,Your ID #,Check Num,Completed?,Canceled,Cost\n");
$wa_startindex = 0;
while(!$rsRESULTS->atEnd()) {
$wa_startindex = $rsRESULTS->Index;
$job_orderID = $rsEXPORT->getColumnVal('orderID');
$job_date = $rsEXPORT->getColumnVal('start_date');
$job_media_cost = $rsEXPORT->getColumnVal('media_cost');
$job_company = $rsEXPORT->getColumnVal('company');
$job_pub_name = $rsEXPORT->getColumnVal('pub_name');
$job_job_title = $rsEXPORT->getColumnVal('job_title');
$job_start_date = $rsEXPORT->getColumnVal('start_date');
$job_invoiceNUM = $rsEXPORT->getColumnVal('invoiceNUM');
if ($rsEXPORT->getColumnVal('pub_inv_num') != "0") {
$job_pub_inv_num = $rsEXPORT->getColumnVal('pub_inv_num');
} else {
$job_pub_inv_num = "";
if ($rsEXPORT->getColumnVal('rs_check_num') != "0") {
$job_rs_check_num = $rsEXPORT->getColumnVal('rs_check_num');
} else {
$job_rs_check_num = "";
if ($rsEXPORT->getColumnVal('complete') == "0") {
$job_complete = "NO";
} else {
$job_complete = "YES";
if ($rsEXPORT->getColumnVal('killed') == "0") {
$job_killed = " ";
} else {
$job_killed = "YES";
if ($rsEXPORT->getColumnVal('mailed') != "0") {
$job_mailed = $rsEXPORT->getColumnVal('mailed');
} else {
$job_mailed = " ";
$job_company = preg_replace("/,/", "", $job_company);
$job_job_title = preg_replace("/,/", "", $job_job_title);
$job_pub_name = preg_replace("/,/", "", $job_pub_name);
fwrite($fp, "$job_pub_name,$job_company,$job_job_title,$job_date,$job_orderID,$job_pub_inv_num,$job_rs_check_num,$job_complete,$job_killed,$job_media_cost,$job_mailed,$job_invoiceNUM,\n");
$rsRESULTS->moveNext();
$rsRESULTS->moveFirst(); //return RS to first record
unset($wa_startindex);
unset($wa_repeatcount);
fclose($fp); ?>
You are looping on $rsRESULTS but adding data from $rsEXPORT.
You would need to loop on the same recordset you are getting content from for the rows to change.
vernon webb
Because I'm an idiot. Too much on my hands. Now it's only returning one record. How do I echo the recordset to screen? I used to use
echo $query_rsEXPORT;
echo $RecordsetName->debugSQL();
vernon webb
The recordset returned is right. Only it's return just the one record in the spreadsheet. Thoughts?
The number of rows is set in the WA_MySQLI_RS() function call as the second argument. If it currently has ,1 change it to ,0 and it will return all results.
vernon webb
Thanks that worked. I have to remember that.
vernon webb
BTW, the same results page above has to forms on it that update. The COMPLETE and CANCELED columns that are not updating. I'm thinking it has to do with the same issue as the other pages? I did download the files you said to my computer (I assume you mean in the WebAssist folder within the site).
How do I browse to the non-functioning pages? What are you supposed to click on to update the Complete or Cancelled value? I'll need more information to help understand what I'm looking at.
vernon webb
The words themselves are buttons. Clicking INCOMPLETE will change it from INCOMPLETE to COMPLETE as well the CANCEL button.
