New Problem
Thread begun 5/17/2018 8:42 am by vernon webb | Last modified 5/17/2018 1:45 pm by Ray Borduin | 2313 views | 5 replies |
vernon webb
New Problem
I open a recordset to change it from mysql to mysqli and get the following attached message. BTW I am able to open the DynamicList selector on the other page so that is now working.
That is an error in the database connection. Usually with the site definition and not being able to connect to the testing server.
vernon webb
I'm unable to connect to the database now, no idea why. I removed DataBridge and the configuration folder as the new Beta was not updating (all updated afterwards) but now am unable to connect. I can connect but no tables show...
Your connection scripts appear to be out of date. I uploaded new ones on my side and the connection started working. Did you install any extensions after DataBridge BETA that may have overwritten the connection scripts with older versions?
vernon webb
yes I installed the DataExtender I guess that messed it up. The connection is working fine however I am still getting that UNKOWN script running in the background message.
I've replied to that issue in the other thread you have open where it was posted.
