WA_SiteTools_ProgressV2.js
Thread begun 5/15/2018 8:22 am by Jose | Last modified 5/16/2018 9:26 am by Ray Borduin | 4223 views | 11 replies |
Jose
Hi there, I'm getting this message that is in the screenshot while I try to insert a form ref to (WA_SiteTools_ProgressV2)
as soon the message appear the process stops creating the form. How it can be fixed?
This is probably an issue with the page that you are adding a form to. Mismatched html or a missing body tag. If you attach a copy of the page I can try to reproduce the problem and help you use the wizard properly.
Jose
I just created a php file in Dreamweaver and it content html and body tag but I get the message also. It creates the form but I always get that message and Site tools progress stop. See the picture.
Do you have the DataBridge BETA installed? This looks like an error in the template code that was added for the beta. I've just done a new build. If you reinstall the BETA this error should go away.
Jose
Yes, I'm using DataBridge BETA
Reinstall and this issue should be fixed.
Jose
Okay, thank you Ray
Jose
that issue causes problems uninstalling Data Bridge . The process can not be finished so I closed Dreamweaver and reinstall it. But when I use send email I can't bind the field. SELECT DATA look like lock. I uninstalled several time and due to that message it wasn't uninstalled correctly. so I reinstall with this issue. I think that due to that error I can not binding from the mene
Can you send a screen shot of the current issue? I'll need that to try to reproduce and fix the problem.
Jose
Here you are. I sent two examples
