Error When Opening Dreamweaver After Installing Latest Build
Thread begun 5/15/2018 6:06 am by vernon webb | Last modified 5/15/2018 1:53 pm by Ray Borduin | 2137 views | 4 replies |
vernon webb
I have gotten the attached message when opening Dreamweaver. Just installed the latest build.
vernon webb
FYI, the Dynamic selector button doesn't work at all. I click it and nothing happens.
This is probably a conflict with the older version you had installed. The error causes the Dynamic Select List UI to not open, so that isn't a surprise.
Can you try closing dreamweaver and deleting the local user's Configuration folder before reinstalling? That would ensure all of the files are replaced with the latest version. In the meantime I'll work on a permanent solution.
vernon webb
It did not work. Same issue
I pushed a new build that should address this:
http://www.webassist.com/DataBridge_BETA_V2-0-3.zxp
