login mysql conversion
Thread begun 5/15/2018 12:52 am by Jamie | Last modified 5/15/2018 12:02 pm by Ray Borduin | 2406 views | 3 replies |
Jamie
He ray, just trying to convert this login to mysqli and the wizard removes columns
Column: UserEmail not present within table (and alsoe UserPassword, UserID, UserGroupID, UserFirstName, UserLastName and UserEmail
if(isset($_POST["LogIN"]) || isset($_POST["LogIN_x"])){
$WA_Auth_Parameter = array(
"connection" => $PowerCMSConnection,
"database" => $database_PowerCMSConnection,
"tableName" => "pcms2_users",
"columns" => explode($WA_Auth_Separator,"UserEmail".$WA_Auth_Separator."UserPassword"),
"columnValues" => explode($WA_Auth_Separator,"".((isset($_POST["userName"]))?$_POST["userName"]:"") ."".$WA_Auth_Separator."".((isset($_POST["Password"]))?$_POST["Password"]:"") .""),
"columnTypes" => explode($WA_Auth_Separator,"text".$WA_Auth_Separator."text"),
"sessionColumns" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserGroupID".$WA_Auth_Separator."UserFirstName".$WA_Auth_Separator."UserLastName".$WA_Auth_Separator."UserEmail"),
"sessionNames" => explode($WA_Auth_Separator,"UserID".$WA_Auth_Separator."UserGroupID".$WA_Auth_Separator."UserFirstName".$WA_Auth_Separator."UserLastName".$WA_Auth_Separator."UserEmail"),
"successRedirect" => "",
"failRedirect" => "",
"gotoPreviousURL" => FALSE,
"keepQueryString" => FALSE
WA_AuthenticateUser($WA_Auth_Parameter);
also getting the ame on the forgot password page with
if(($_SERVER["REQUEST_METHOD"] == "POST") && (isset($_SERVER["HTTP_REFERER"]) && strpos(urldecode($_SERVER["HTTP_REFERER"]), urldecode($_SERVER["SERVER_NAME"].$_SERVER["PHP_SELF"])) > 0) && isset($_POST)){
//WA SecurityAssist Email object="mail"
"filterColumn" => "UserEmail",
"filterEncryption" => "",
"columnValue" => "".((isset($_POST["Email"]))?$_POST["Email"]:"") ."",
"columnType" => "text",
"usernameColumn" => "UserEmail",
"usernameEncryption" => "",
"passwordColumn" => "UserPassword",
"passwordEncryption" => "",
"selectColumns" => array("UserEmail","UserPassword"),
"sessionVariables" => array(""),
"successRedirect" => "/admin_cms/users_login.php?emailedPassword=1",
"failRedirect" => "forgotpassword.php",
"keepQueryString" => FALSE,
"toAddressColumn" => "UserEmail",
"toAddressEncryption" => "",
"fromAddress" => "noreply@motley.site",
"fromAddressDisplay" => "Motley.site",
"subject" => "Motley.site CMS Password Reminder",
"mailBody" => "../webassist/security_assist/email/forgotpassword_email.php",
"emailFunction" => "WA_SecurityAssist_Email_1_SendMail"
WA_Auth_ForgotPassword($WA_Auth_Parameter);
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
What page on what site? I'll have to open the file and debug it.
Jamie
I think I have the first one sorted but the second one is on the site you helped me with the other day and its in the admin_cms folder and is forgotpassword.php
I seem to be able to open the forgot password SecurityAssist Email Password server behavior without errors.
What are the steps to reproduce the problem? What is the site and page you are opening? I'll need to reproduce the issue to work on it, but so far I've been unable to.
