super admin v user
Thread begun 5/14/2018 8:25 am by Jamie | Last modified 5/15/2018 8:49 am by Ray Borduin | 1128 views | 2 replies |
Jamie
super admin v user
Hey Ray
How would I modify this select statement
SELECT * FROM client_help WHERE Live = 1 ORDER BY HelpOrder ASC
so that if you are super admin results that have column Hidden = 1 are visible but not if you're not super admin. All results (apart from where Hidden = 1) are visible to both super admin and non super admin
Is this MySQLi or standard MySQL? It would be done in the PHP not just the SQL statement. I'd probably just do:
SELECT * FROM client_help WHERE Live = 1 OR 1 = ? ORDER BY HelpOrder ASC
Then use a parameter that you set to 0 for non admin and set to 1 for admin so that admin would end up with:
SELECT * FROM client_help WHERE Live = 1 OR 1 = 1 ORDER BY HelpOrder ASC
and non admin will have:
SELECT * FROM client_help WHERE Live = 1 OR 1 = 0 ORDER BY HelpOrder ASC
Jamie
thanks Ray
