Login Troubles
Thread begun 5/11/2018 10:59 am by vernon webb | Last modified 5/18/2018 12:27 pm by Ray Borduin | 7488 views | 21 replies |
vernon webb
Login Troubles
OK, so you fixed the login page first and now I'm beginning to realize that there was a session set "MM_Username1" that is no longer working throughout the site. I went in to look at the login details in Dreamweaver and Dreamweaver hangs for a time and then crashes.
Where is the code that depends on that session value? What is it supposed to be set to? What is it used for? That looks like the old adobe standard page restriction code, you should probably just delete it and apply the security assist page restriction server behavior instead.
vernon webb
OK so I've tried to recreate everything from scratch. I only need the login page and the logout page. Not sure if it's my system, the server I'm connecting to or what but it's painfully slow to try and do anything. That said, I went to the Manage Page panel and when I attempt to delete any other page (registration, update, etc) Dreamweaver crashes.
I was able to reproduce a crash when deleting pages from the SecurityAssist wizard. I'll get that fixed.
In the meantime, go ahead and let it generate those pages and then just delete them after the wizard runs. You will just have to delete the link to the forgot password page from the login page and then update the login server behavior success redirect to go to a different page than the profile page you deleted.
vernon webb
Right that is what I was saying. I opened the Security Assist Wizard tried deleting pages I didn't need and it crashed out Dreamweaver
Yes. I will look into it and get that fixed.
vernon webb
OK so I created all the new pages and it simply hangs during login and I eventually get an error page that says Failed to open page
The forgot password page was missing a necessary include file:
<?php require_once("webassist/security_assist/helper_php.php"); ?>
The login page seems to open for me. What username and password should I use? It seems to work for failed logins.
vernon webb
below
vernon webb
The forgot password page doesn't send me my password, doesn't fail, just show the same page each time.
