Switching over to MySqli
Thread begun 5/09/2018 3:59 pm by drymetal427575 | Last modified 5/10/2018 9:39 am by Ray Borduin | 1082 views | 2 replies |
drymetal427575
I used dataassist and security assist to create a website. Now my server won't let it work because it says that mysql is no longer valid. Is there an easy way to switch this over to mysqli? If I have to build it from scratch tonight, do I need Dreamweaver CC or CS6? The site has authentication, CRUD functionality. I should have all the products I need to do this?
Thanks!
Chad
It is highly likely that you can ask your hosting provider to install php 5.6 and you can continue using your existing code. Or you can switch hosting providers, because most will let you choose your php version. The only version your code won't work on is PHP version 7.
In order to upgrade your pages you can download and install the DataBridge 2 beta linked on the top of this web site. It has conversion functionality that can do most of the work for you.
drymetal427575
Thanks!
Thank you for the help! I'll go ahead and redo it with the BETA. Thanks for all you guys do!
