Another
Thread begun 5/09/2018 8:38 am by vernon webb | Last modified 5/10/2018 10:21 am by Ray Borduin | 2003 views | 4 replies |
vernon webb
Another
Updated this one but the field only shows one record. I thought you said you change the 1 to a 0 here, but that didn't help
You also have to re-apply the dynamic select list server behaviors.
Delete the server code that is currently around the <option> tag in your select list. Then go into the select list properties and click the dynamic button to populate it from the newly created mysqli recordset.
vernon webb
Not sure what you mean. Are you talking about the do/while code? Here is my code:
Yes, delete the do - while code and the <option> tag in between and then click the lightning bolt from the properties panel and you should be able to re-populate the dropdowns with the mysqli recordsets instead.
vernon webb
Got it
