More MySQLi
Thread begun 5/09/2018 7:47 am by vernon webb | Last modified 5/10/2018 10:22 am by Ray Borduin | 1279 views | 2 replies |
vernon webb
More MySQLi
After updating and fighting with my server people I am having a hard time figuring out what a 503 Error means. After updating the code this seem to happen. Look at this page... thoughts
The error is happening when the code uses the function "mysqli_stmt_bind_result". This function is used to return results from prepared statements. I'm not sure why this happens on your server. I would guess it is a server configuration issue, but it is really hard to say.
One solution is to turn off prepared statements in the rsobj.php file. I've done that and your pages now appear to open properly, but it is more of a work around than a solution since I think the issue is in the server or database itself.
Have you tried running a repair on the database and rebooting the server? That might work as well. Does it work in your local testing environment?
vernon webb
I have, for the moment while testing and rewriting, moved to another server. Will address it later if need be. Too much on my plate to be troubleshooting someone else's server. ;)
