checkboxes to text fields
Thread begun 5/06/2018 4:58 pm by vered435903 | Last modified 5/11/2018 5:35 pm by Ray Borduin | 1753 views | 4 replies |
vered435903
Hello,
I recently made a form that is sending to both email and updating a database. I changed two fields to be text fields from y/n checkboxes. The information is being sent to the email correctly, but it's still displaying y or n in the database. I'm sure I'm just neglecting to update something simple... Please help.
Here is the link:
http://prodew.com/forms/installer_intro.php
You can see the two y/n questions that now have text fields: have you installed systems and can you house inventory. The database fields are set to varchar(10) so that shouldn't be causing this issue.
Thank you!
Please attach a copy of the page. I'll need to look at the code to see what is wrong.
vered435903
Hello Ray,
I'm so sorry for the delay in my reply. This has been quite a week...
I've attached the file. Let me know what you find.
Thanks!
Open the MySQLi Insert Record server behavior and go to the Bindings tab. Select the columns you want updated and change the data type from "Checkbox y/n" to "text".
vered435903
Thanks Ray! I knew it had to be something simple.... I'll work on it this weekend and will let you know if I have any other issues.
Thanks again for all your continued help! Have a good weekend!
