Blank Page
Thread begun 5/02/2018 11:09 am by vernon webb | Last modified 5/02/2018 3:00 pm by Ray Borduin | 3670 views | 7 replies |
vernon webb
Blank Page
This post has been deleted.
Blank pages often mean the page has an error, but errors are set not to display. To see the error on the page, add this code to the top:
ini_set('display_errors',1);
vernon webb
Sorry the blank page was because I never uploaded the file. I got the page to work, but it's not displaying all the results, only one
The number of results to display is in the recordset code.
If you find lines like this:
new WA_MySQLi_RS("cNAME",$connIO_i,1);
the 1 at the end is the number of results to show. Change it to zero to show all results or set it to the number of rows you want returned.
Just search for: "new WA_MySQLi_RS" and you can go through each recordset and set the correct number of rows.
vernon webb
That did nothing, sorry to say
Then probably the repeat region code didn't update. Delete the repeat region code around the <tr> that you have currently and then apply the MySQLi repeat region to the row again.
vernon webb
It's telling me that that recordset doesn't exist but it does, but it does.
This is when you are applying the MySQLi repeat region server behavior? Or are you opening the old one? If you are opening the old one that message might make sense since the old MySQL recordset no longer exists.
