Repeat Selections
Thread begun 5/02/2018 7:04 am by Sweens | Last modified 5/11/2018 1:58 pm by Ray Borduin | 3863 views | 10 replies |
Sweens
Repeat Selections
Hi Ray
I've applied the change from mysql to mysql_i recordsets, and immediately get many errors; I've tried to eliminate them one by one - but all that happens is more appear! I'm stumbling around not really knowing what I'm doing.
Pages attached - original (working) and new (not working!)
Chris
I'll need a url to reproduce and ftp access to debug. I'll need to run the files and see the errors in order to determine what is going wrong.
Sweens
See pm
I can't seem to log in with that username and password. Please check to see if there are any typos.
Sweens
Oops! Lower case s
It was pretty close. I ended up manually deleting the repeat selection code and reapplying simple MySQLi Repeat Regions and that seems to have fixed it.
Sweens
Many thanks Ray - hope it helps with the extension.
Cheers
Chris
Sweens
HI Ray
Having the same problem on a different page; every time I try to apply either version (Repeat Selection or Repeat Selection Improved) I get the dreaded 'A javascript error occurred' message. Cleared the cache etc, but cannot get it to work.
Attached is the non-working version, I have removed the old region and tried to start from scratch; lines 24-253 need to repeat.
Same login details as earlier in the thread.
Many thanks
Chris
I was able to reproduce the error. For now just use "MySQLi Repeat Region" the repeat selection is only needed for horizontal looping when nested within a Repeat Region.
I'll try to get a build out with a fix later today.
Sweens
Thanks Ray; I'm assuming the MySQLi Repeat Region won't be sufficient for a multiple update - so I'll wait for the fix. No rush.
Cheers
Chris
