KCFinder
Thread begun 4/30/2018 7:48 am by Jamie | Last modified 5/02/2018 9:15 am by Ray Borduin | 5355 views | 17 replies |
Jamie
KCFinder
Hi Ray
Have uploaded the kcfinder folder from %APPDATA% as you showed the other day and uploaded it, but when go to the server I get this error:
Notice: Use of undefined constant SECURITY_RULE - assumed 'SECURITY_RULE' in /home/motle7bk/public_html/clients/template_new/webassist/kcfinder/conf/config.php on line 9
- link in pm so you can see it in action
Also, how do you set the default upload folder?
Go to Webassist->Form->HTML Editor->Site Settings
That should allow you to set the security rule and upload folder.
If that doesn't work yet you may have to manually update the file:
Jamie
ok, have done that - what folder/files need uploading once thats done?
Just the config.php file that I referenced above.
Jamie
oK uploaded and now it doesnt link to kcfinder at all.... config file attached
What doesn't link at all? The issue may not be in the config file. The config file looks correct to me.
Jamie
it takes me through to a [FAIL_REDIRECT] page. I have tried changing it to the index.php in the root of the kcfinder folder and then that just takes me to not allowed to access (have set the security rule to publisher or editor and logged in as super admin
before I changed the cnfi file it took me to the kcfinder interface, I just had that error and this was what I saw wth the original config file: http://prntscr.com/jcf8ez
That means that it is failing the Access rule... and that no fail redirect page was set.
You can set the fail redirect page on line 23 to go to your login page.
Is this a powercms installation? If so we probably have to add a require_once() for the globals.php file on the top of the config page as well.
Jamie
OK, have added a fail redirect and added the globals.php and now it just redirects to the login page which is auto directing to an update page because it recogises that I am logged in....kcfinder is not recognising that I am logged in
What site is this on? I'll take a look.
