Fatal error: Uncaught Error: Call to a member function fetch_array()
Thread begun 4/29/2018 2:30 am by Mike | Last modified 5/01/2018 11:49 am by Ray Borduin | 11279 views | 6 replies |
Mike
Hello,
I've a website with an admin area where I used MySQLi extension to build the dynamic behaviours.
Now, I receive this error when I try to open a page in the browser:
Fatal error: Uncaught Error: Call to a member function fetch_array() on boolean in /var/www/vhosts/mydomain.com/httpdocs/webassist/mysqli/rsobj.php:158 Stack trace: #0 /var/www/vhosts/mydomain.com/httpdocs/admin/sitemanager/index.php(26): WA_MySQLi_RS->execute() #1 {main} thrown in /var/www/vhosts/mydomain.com/httpdocs/webassist/mysqli/rsobj.php on line 158
The version used of "rsobj.php" is the 2.18.
Any ideas how can I fix this issue?
Can I get FTP Access and a URL to reproduce?
This error means you have an issue with either your connection or SQL statement, but it shouldn't be such a hard to understand error. I'd like to take a look and tell you what is wrong and then make sure that in the future the error is easier to understand.
Mike
Hi Ray,
I resolved the issue removing the old "rsobj.php" file (v. 2.18) with that included (v. 2.6) in the alpha version of the new DataBridge.
A question, is it safe to use this file (and queryobj.php) in a production-ready works or the alpha version of DataBridge is still too unsafe/unstable?
I'm using it on several sites currently, but there is of course some risk since maybe not all parts are fully tested. I think in the worst case something may not work properly it wouldn't be a security hole. If it doesn't work for something, then you can always post here and I'll be sure to look into it and get it fixed as quickly as I can.
Mike
Ok, thanks Ray.
A last question... how can I know if the file has been updated in the progress of the various beta?
Should I just open a PHP file and update a recordset or is necessary delete the file "rsobj.php" and regenerate it?
The rsobj.php includes a version number on the top. It will be automatically updated if the version has been updated in the build and you use a server behavior that takes advantage of that file... so if you update a recordset the local version will be updated if the version number has changed.
Mike
Ok, thanks!
