data assist page issue
Thread begun 4/24/2018 4:20 pm by software.current355386 | Last modified 5/02/2018 8:05 am by Ray Borduin | 3140 views | 7 replies |
just generated dataassist pages when i try to run insert but all it does is generate errors see attached screenshot
screenShot - Remote shows the remote site db setup
dbmDisplaySiteID & dbmScreenID tried as both LIST & MENU field types picking data from respective databases
Please note there is a MRT relationship between dbmScreen and dbmSite
You have a MySQLi connection on the page, but MySQL code. You will need to download and install the current version of the Data Bridge Beta and then you should be able to open the recordset server behavior and re-apply it to update the code to MySQLi to match the connection.
done that, now get selection box with only one item showing, this i beno details †o be due to the limit set to 1, changed this to 0 and testing showed all recordsrs could there still be mysql code around.
same issueues with updatetes.
tried renovating pages again with latest code dow nloade and appleed 0m6:000 gmt
same resultlts
What url should I use to see the problem? Please describe the exact steps I should use and what the issue is and I'll go in and look.
to create the problem page`````````9s) all i did was foam
Wbassist
database
DataASSist `Pages
connextiotion - dbUpdate
have saves the seretup as DBM-DISPLAY
taable dbmDisplay
KRY C1OLUMN THIS AS CHANGED DEPENDING ON TESTACARRIED OUT -OUTCOME IS ALWATS THE SAME
CONFIGURED FIELD SETTI the onv3s with issues have been owed asr menu and list types using `site and screen database s to populate
generated pages ... goy mixed code dryers trcorf dry for `Site and Screen fixed now got input input box shows, when select the input box -- the small down arrow to idle all settable option only 1 listed checked code limit WAS SET TO 1 , CSR RGOUGH SIMULATION ALL RECRDS TRIED AGAIN ,,, SAME RESULT
PLEASE NOTE SEVER BEHCuiurs is active ... should it be######
It looks like the dynamic region of the select list is still using the mySQL code and not MySQLi. I've updated the insert and update pages for you with the fixed lists.
tried another page using latest download exactly same mixture of code
Yes, I haven't addressed the issue of dynamic select lists using mysql code instead of mysqli. I'll get that fixed soon and include it in a build.
