converting search
Thread begun 4/23/2018 7:19 pm by Jamie | Last modified 4/25/2018 9:46 am by Ray Borduin | 1587 views | 3 replies |
Jamie
converting search
Hey Ray
Just tried converting a search from
//WA Database Search (Copyright 2005, WebAssist.com)
//Recordset: WADAproducts;
//Searchpage: test.htm;
//Form: SearchForm;
$WADbSearch1_DefaultWhere = "";
if ((isset($_POST["WADbSearch1"])) && ($_POST["WADbSearch1"] != "")) {
$WADbSearch1 = new FilterDef;
$WADbSearch1->initializeQueryBuilder("MYSQL","1");
//keyword array declarations
$KeyArr1 = array("ProductID", "ProductSKU", "ProductName", "ProductPrice", "ProductLongDesc", "CategoryName", "ManufacturerName");
//comparison list additions
$WADbSearch1->keywordComparison($KeyArr1,"".((isset($_POST["SearchContent"]))?$_POST["SearchContent"]:"") ."","AND","Includes",",%20","%20","%22","%22",0);
//save the query in a session variable
if (1 == 1) {
$_SESSION["WADbSearch1_product_results"]=$WADbSearch1->whereClause;
else {
//get the filter definition from a session variable
if (1 == 1) {
if (isset($_SESSION["WADbSearch1_product_results"]) && $_SESSION["WADbSearch1_product_results"] != "") {
$WADbSearch1->whereClause = $_SESSION["WADbSearch1_product_results"];
else {
$WADbSearch1->whereClause = $WADbSearch1_DefaultWhere;
else {
$WADbSearch1->whereClause = str_replace("\\''", "''", $WADbSearch1->whereClause);
$WADbSearch1whereClause = '';
to
$searchWADAproducts_1 = new WA_MySQLi_Search("WADAproducts","");
$searchWADAproducts_1->clearSearch();
$searchWADAproducts_1->setSearch(array("type"=>"Key", "comparison"=>"Includes", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ProductID", "ProductSKU", "ProductName", "ProductPrice", "ProductLongDesc", "CategoryName", "ManufacturerName"), "s", "".((isset($_POST["SearchContent"]))?$_POST["SearchContent"]:"") ."");
and when you go to the results page the error is shown:
[codeSELECT products.*, productcategories.*, GROUP_CONCAT(CategoryName SEPARATOR ', ') AS AllCategories FROM products LEFT JOIN productcategoryjoin ON JoinProductID = ProductID LEFT JOIN productcategories ON JoinCategoryID = productcategories.CategoryID WHERE ((`ProductID` Includes ?) OR (`ProductSKU` Includes ?) OR (`ProductName` Includes ?) OR (`ProductPrice` Includes ?) OR (`ProductLongDesc` Includes ?) OR (`CategoryName` Includes ?) OR (`ManufacturerName` Includes ?)) GROUP BY ProductID
You have an error in your SQL syntax; check the manual that corresponds to your MySQL server version for the right syntax to use near 'Includes ?) OR (`ProductSKU` Includes ?) OR (`ProductName` Includes ?) OR (`Prod' at line 1[/code]
I have also tried removing the search code and doing it from scratch and using
if (isset($_POST["WADbSearch1"]) || isset($_POST["WADbSearch1_x"])) {
$searchWADAproducts_1->setSearch(array("type"=>"Key", "comparison"=>"Includes", "join"=>"AND", "and"=>", ", "or"=>" ", "start_encap"=>"\"", "end_encap"=>"\""), array("ProductSKU", "ProductName", "ProductLongDesc"), "s", "".(((isset($_POST["SearchContent"]))?$_POST["SearchContent"]:"")) ."");
and that ends up with an error
What version is listed in your rsobj.php file?
Jamie
it was 2.18 but have now uploaded 2.5. Now only getting "There is an error in your SQL syntax." as the error on page load.
Open the rsobj.php file and turn on Debug in the settings near the top of the page. That will give you a better error that should lead you to the cause.
