Problems with XML SiteMap in Dreamweaver CS4
I am receiving error messages in Dreamweaver CS4 when trying to create an XML site map. I have attached a capture of one of the messages.
I don't see the error message attached. Could you try attaching it again?
Also, what is the site you are trying to survey? Is it a local site or a remote site?
What steps do you take before you get the error message? Where are you accessing Surveyor from (insert menu, WebAssist Site Tools, Insert Bar)?
OK, I've re-attached the screen capture.
I am accessing the XML Sitemap in DW CS4 via the WA Insert on the right of my screen. I've tried this with both remote & local sites & still get the same series of errors about JavaScript.
The steps I take ares follows:
1. Start XML Sitemap from the WA Insert bar
2. Select "Create From Site"
3. Click "Next"
4. Configure Link Settings
5. Click Finish
6. Screen Shot 1 appears
7. Click OK
8. Try clicking "Finish" again.
9. Screen Shot 2 appears
10. Click "OK"
11. Click "Cancel"
12. A final message pops up saying that JavaScript errors have occurred.
Thanks for the screen shots. have you tried deleting your winfilecache file.
If the problem still exists after deleting your cache file, could you tell me what version of Surveyor you are using.
