Facebook Like Button not visible in PS V454
Thread begun 4/19/2018 3:57 pm by msjj000 | Last modified 4/23/2018 12:49 pm by Ray Borduin | 940 views | 2 replies |
msjj000Beta Tester
Hi Webassist,
I used the same method as in PS3 and as recommended by FB however the like button isn't showing. I checked the FB threads and most folk with the same error was due to geographic and age restrictions on the specific FB page that was being linked (settings that were fine for me).
I have also removed the https default which worked on PS3.
Any suggestions? Twitter, GeoTrust and other external links work.
site: www.ridewerx.com/index.php
changes made to index.dwt.php as per the following page: https://developers.facebook.com/docs/plugins/like-button#
JS inserted straight after first body tag (line 22 index.dwt.php). link to view inserted under the twitter feed in ps_pod3/News/Body .
Thanks, Mark.
I made an update to the webassist/framework/framework.php file to fix this issue on your site.
msjj000Beta Tester
FB like button now showing
Thank you as always Ray - much appreciated.
