Upload Behaviour Broken?
Thread begun 4/17/2018 7:26 am by Steve | Last modified 4/17/2018 11:36 am by Ray Borduin | 583 views | 1 replies |
Steve
First I could only get the file name to post and now only the ext is used as the name when uploading and the Name is set to the DB but NOT the extension...
// WA_UploadResult1 Params Start
$WA_UploadResult1_Params = array();
// WA_UploadResult1_1 Start
$WA_UploadResult1_Params["WA_UploadResult1_1"] = array(
'UploadFolder' => "../classes-uploads/",
'FileName' => "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]) ."",
'DefaultFileName' => "".(((isset($_POST["hdn_fileName"]))?$_POST["hdn_fileName"]:"")) ."",
'ResizeType' => "0",
'ResizeWidth' => "0",
'ResizeHeight' => "0",
'ResizeFillColor' => "" );
// WA_UploadResult1_1 End
// WA_UploadResult1 Params End
WA_DFP_SetupUploadStatusStruct("WA_UploadResult1");
if(isset($_POST["submit"]) || isset($_POST["submit_x"])){
WA_DFP_UploadFiles("WA_UploadResult1", "file_suplmt", "2", "[NewFileName]_[Increment]", "false", $WA_UploadResult1_Params);
Steve
Works after manually changing to
'FileName' => "[FileName]",
Key was this update:
Also change the Update parameter to:
$UpdateQuery->bindColumn("classSuplmtFile", "s", "".($WA_DFP_UploadStatus["WA_UploadResult1"]["serverFileName"]) ."", "WA_DEFAULT");
Prior was:
$UpdateQuery->bindColumn("classSuplmtFile", "s", "".(((isset($_FILES["file_suplmt"]))? preg_replace('/.[^.]*$/', '', $_FILES["file_suplmt"]["name"]) :"")) ."", "WA_DEFAULT");
