universal mail pear is causing errors.
Thread begun 4/13/2018 9:08 pm by dcb286193 | Last modified 5/10/2018 10:19 am by Ray Borduin | 3691 views | 9 replies |
dcb286193
This post has been deleted.
This means that the Mail portion of PEAR is not installed properly. I'd suggest using the Data Bridge BETA. It allows you to send authenticated email without PEAR.
dcb286193
thanks Ray. I figured out the issue. I did not set the path correctly went to far into the mail folder of pear instead of pointing to the Mail.php file first. No issue just my ignorance of not knowing how to use pear correctly. problem solved.
dcb286193
I am receiving an error when trying to do the final submit of my checkout page. Looks as if its not pulling the information from eCart during the email generation [GetContent() generating null]. Still trying to get this up and running. Have installed the beta version as suggested but don't understand how to setup verification without PEAR and if this error has anything to do with universal email.
Please attach the page: webassist/email/templates/order-confirmation.php as well as the page where the email is applied and I can take a look.
dcb286193
attached are the files
It looks like you didn't include the file: webassist/email/templates/order-confirmation.php
After looking at the others, that is the file that needs to be updated.
dcb286193
it was their just not in the folders. Here are the files in the correct folders.
Update the code on top of that page. Instead of:
//WA eCart Include
require_once("/home/ipmlitho/public_html/webassist/eCart/eCart_PHP.php");
$eCart
->GetContent();
if (0==1) { // code added to make sure Dreamweaver does not show the Server behaviors as broken ?>
//WA eCart Include
require_once("../../../WA_eCart/eCart_PHP.php");
$eCart
->GetContent();
// WA eCart Redirect
if ($eCart->redirStr != "")     {
  if (
function_exists("rel2abs")) $eCart->redirStr = rel2abs($eCart->redirStr,dirname(__FILE__));
header("Location: ".$eCart->redirStr);
  die();
//WA eCart Include
require_once("../../eCart/eCart_PHP.php");
$eCart
->GetContent();
if ($WA_Store_Cart->redirStr != "")     {
header("Location: ".$WA_Store_Cart->redirStr);
use:
global $eCart;
//WA eCart Include
$eCart
->GetContent();
  if (
  die();
dcb286193
Thanks Ray, just could not see the issue, your the best!
