Limit 2, 4 not returning correct rows
Thread begun 4/11/2018 9:51 am by cal114936 | Last modified 4/12/2018 10:41 pm by Ray Borduin | 1092 views | 2 replies |
cal114936Beta Tester
The limit parameter works fine when testing in the server behavior, but is returning the wrong rows in the repeat on the page.
This should be returning records 3 through 6 correct? But I actually only get records 1 and 2. on the page. Testing within the Server Behavior dialog box returns the correct set.
$rsFeatures2 = new WA_MySQLi_RS("rsFeatures2",$nMedia3_i,2,4);
$rsFeatures2->setQuery("SELECT content1.contentID, content1.featureDate, content1.headline, content1.photo1, content1.caption1, content1.para1 FROM content1 ORDER BY content1.featureDate DESC");
$rsFeatures2->execute();
while(!$rsFeatures2->atEnd()) {
<div class="text-center marginBottom30">
<a href="content.php?contentID=<?php echo($rsFeatures2->getColumnVal("contentID")); ?>"><img class="featurePhoto" src="https://hotvws.com/images/hot_vws_articles/<?php echo($rsFeatures2->getColumnVal("contentID")); ?>/<?php echo($rsFeatures2->getColumnVal("photo1")); ?>" alt=""/></a>
<h3 class="marginTop10"><?php echo($rsFeatures2->getColumnVal("headline"));?></h3>
<p><?php echo (wordCutString($rsFeatures2->getColumnVal("para1")));?>... <a href="content.php?contentID=<?php echo($rsFeatures2->getColumnVal("contentID")); ?>">Read More</a></p>
</div>
$rsFeatures2->moveNext();
$rsFeatures2->moveFirst(); //return RS to first record
?> </div>
Thanks for any insight
Pagination (setting the start row), is currently only possible through a url parameter. I see what you are trying to do though... I'll update the BETA to allow you to set a start row in the way you are attempting. However that will break pagination, so you couldn't use that technique in conjunction with next and previous buttons.
I'll get a new BETA out later tonight with the update. I think for now you can get around it by using the SQL statement to set the limit directly like:
$rsFeatures2
= new WA_MySQLi_RS("rsFeatures2",$nMedia3_i,0);
$rsFeatures2->setQuery("SELECT content1.contentID, content1.featureDate, content1.headline, content1.photo1, content1.caption1, content1.para1 FROM content1 ORDER BY content1.featureDate DESC LIMIT 2,4");
Thanks Ray!
