I am getting this error: Fatal error: Uncaught Error: Class 'mysqli_connect' not found in /Library/WebServer/Documents/Leathernecks/Connections/leatherneck_i.php:10 Stack trace: #0 /Library/WebServer/Documents/Leathernecks/comm_t4t.php(1): require_on
Thread begun 4/07/2018 7:52 am by randyrie405335 | Last modified 4/16/2023 2:59 pm by Ray Borduin | 8258 views | 5 replies |
randyrie405335
I am getting this error: Fatal error: Uncaught Error: Class 'mysqli_connect' not found in /Library/WebServer/Documents/Leathernecks/Connections/leatherneck_i.php:10 Stack trace: #0 /Library/WebServer/Documents/Leathernecks/comm_t4t.php(1): require_once() #
Fatal error: Uncaught Error: Class 'mysqli_connect' not found in /Library/WebServer/Documents/Leathernecks/Connections/leatherneck_i.php:10 Stack trace: #0 /Library/WebServer/Documents/Leathernecks/comm_t4t.php(1): require_once() #1 {main} thrown in /Library/WebServer/Documents/Leathernecks/Connections/leatherneck_i.php on line 10. How do I correct thr code so the error no longer displays?
What version of PHP are you running? MySQLi was added in php5. You may have a previous version or don't have the MySQLi module installed.
randyrie405335
Uncaught Error
I am using version 7 since my host provider has advised they will be discontinuing PHP 5.* in the near future and I'll need to convert my sites to MySQLi. I do have the latest MySQLi module installed, I purchased the MySQLi server behavior a couple of years ago from Webassist.
The error implies that mysqli is not available on the server.
Can you create a page on your server with this code on it:
phpinfo();
Then send me a link to that page and I'll take a look.
anonymous
Fatal error
Uncaught Error: Class "mysql_connect" not found in D:\php\htdocs\library system\student\login.php:4 Stack trace: #0 {main} thrown in D:\php\htdocs\library system\student\login.php on line 4
Mysql isn't available if you have php version 7 or above. You may need to update the page to use mysqli instead.
