Has the DataAssist Search Wizard Been Modified?
Thread begun 4/06/2018 7:06 am by salaroche | Last modified 4/10/2018 10:54 am by Ray Borduin | 2509 views | 5 replies |
salaroche
Hi, I haven’t used Webassist for some time and now I’m a bit mixed-up regarding how to use it. In the past I have created search sequences that, besides results pages, they also generated Insert, Update and Delete pages. Now I’m using Webassist > Database > DataAssist Search Wizard, but that extension doesn’t give me the option to configure the Insert, Update and Delete pages. Has Webassist modified that extension?
The fact is I’m not sure whether the DataAssist Search Wizard was the extension I had used in the past; I’m under the impression I had used a different one before. Any suggestions?
Thank you in advance for your attention.
Use Webassist->Database->DataAssist Pages
That is the updated version of the wizard you are referring to.
salaroche
Ray, the DataAssist Pages generator works OK but not as well as it used to. Thus far none of the tabs allows for selecting a Template. Is there any way to select a Template for the pages or has that feature been discarded? Thank you for your attention.
That feature has been discarded in favor of using Framework builder. It is an improvement on Dreamweaver templates. You can always apply the template to the page after the wizard runs if you wanted.
salaroche
A discarded but important feature... The "updated" version looks more like a downgrade. I'll try attaching the created pages to a Template and I'll get back to you if I have any difficulties. Is it possible to download the previous version of that extension? Kindly let me know. Thank you for your attention.
If you purchased the older version you can download it at any time from your order history.
