php7 msqli server behaviour
Thread begun 4/03/2018 12:29 pm by smithdunn123 | Last modified 4/04/2018 10:24 am by Ray Borduin | 8735 views | 4 replies |
smithdunn123
I am using xampp with PHP 7 and msqli server behaviours.
Fatal error: Uncaught Error: Call to undefined function mysql_select_db() in C:\xampp\htdocs\index.php:52 Stack trace: #0 {main} thrown in C:\xampp\htdocs\index.php on line 52
Any ideas?
This is after creating a login page and then logging in
<?php require_once('Connections/mbfConnection.php'); ?>
if (PHP_VERSION < 6) {
switch ($theType) {
case "text":
break;
case "long":
case "int":
break;
case "double":
break;
case "date":
break;
case "defined":
break;
return $theValue;
// *** Validate request to login to this site.
if (!isset($_SESSION)) {
session_start();
$loginFormAction = $_SERVER['PHP_SELF'];
if (isset($_GET['accesscheck'])) {
$_SESSION['PrevUrl'] = $_GET['accesscheck'];
if (isset($_POST['email'])) {
$loginUsername=$_POST['email'];
$password=$_POST['password'];
$MM_fldUserAuthorization = "adminlevel";
$MM_redirectLoginSuccess = "/dashboard/";
$MM_redirectLoginFailed = "/";
$MM_redirecttoReferrer = false;
mysql_select_db($database_mbfConnection, $mbfConnection);
$LoginRS__query=sprintf("SELECT username, password, adminlevel FROM `user` WHERE username=%s AND password=%s",
GetSQLValueString($loginUsername, "text"), GetSQLValueString($password, "text"));
$LoginRS = mysql_query($LoginRS__query, $mbfConnection) or die(mysql_error());
$loginFoundUser = mysql_num_rows($LoginRS);
if ($loginFoundUser) {
$loginStrGroup = mysql_result($LoginRS,0,'adminlevel');
if (PHP_VERSION >= 5.1) {session_regenerate_id(true);} else {session_regenerate_id();}
//declare two session variables and assign them
$_SESSION['MM_Username'] = $loginUsername;
$_SESSION['MM_UserGroup'] = $loginStrGroup;
if (isset($_SESSION['PrevUrl']) && false) {
$MM_redirectLoginSuccess = $_SESSION['PrevUrl'];
header("Location: " . $MM_redirectLoginSuccess );
else {
header("Location: ". $MM_redirectLoginFailed );
<!DOCTYPE html>
<html>
<head>
<meta charset="utf-8">
<meta http-equiv="X-UA-Compatible" content="IE=edge">
<title>AdminLTE 2 | Log in</title>
<!-- Tell the browser to be responsive to screen width -->
<meta content="width=device-width, initial-scale=1, maximum-scale=1, user-scalable=no" name="viewport">
<!-- Bootstrap 3.3.7 -->
<link rel="stylesheet" href="bower_components/bootstrap/dist/css/bootstrap.min.css">
<!-- Font Awesome -->
<link rel="stylesheet" href="bower_components/font-awesome/css/font-awesome.min.css">
<!-- Ionicons -->
<link rel="stylesheet" href="bower_components/Ionicons/css/ionicons.min.css">
<!-- Theme style -->
<link rel="stylesheet" href="dist/css/AdminLTE.min.css">
<!-- iCheck -->
<link rel="stylesheet" href="plugins/iCheck/square/blue.css">
<!-- HTML5 Shim and Respond.js IE8 support of HTML5 elements and media queries -->
<!-- WARNING: Respond.js doesn't work if you view the page via file:// -->
<!--[if lt IE 9]>
<script src="https://oss.maxcdn.com/html5shiv/3.7.3/html5shiv.min.js"></script>
<script src="https://oss.maxcdn.com/respond/1.4.2/respond.min.js"></script>
<![endif]-->
<!-- Google Font -->
<link rel="stylesheet" href="https://fonts.googleapis.com/css?family=Source+Sans+Pro:300,400,600,700,300italic,400italic,600italic">
</head>
<body class="hold-transition login-page">
<div class="login-box">
<div class="login-logo">
<b>MBF</b>Admin
</div>
<!-- /.login-logo -->
<div class="login-box-body">
<p class="login-box-msg">Sign in to start your session</p>
<form action="<?php echo $loginFormAction; ?>" method="POST" name="login">
<div class="form-group has-feedback">
<input type="email" class="form-control" placeholder="Email" value="" name="email">
<span class="glyphicon glyphicon-envelope form-control-feedback"></span>
</div>
<input type="password" class="form-control" placeholder="Password" value="" name="password">
<span class="glyphicon glyphicon-lock form-control-feedback"></span>
</div>
<div class="row">
<div class="col-xs-8">
<div class="checkbox icheck">
<label>
<input type="checkbox"> Remember Me
</label>
</div>
</div>
<!-- /.col -->
<div class="col-xs-4">
<button type="submit" class="btn btn-primary btn-block btn-flat">Sign In</button>
</div>
<!-- /.col -->
</div>
</form>
<a href="#">I forgot my password</a><br>
</div>
<!-- /.login-box-body -->
</div>
<!-- /.login-box -->
<!-- jQuery 3 -->
<script src="bower_components/jquery/dist/jquery.min.js"></script>
<script src="bower_components/bootstrap/dist/js/bootstrap.min.js"></script>
<!-- iCheck -->
<script src="plugins/iCheck/icheck.min.js"></script>
<script>
$(function () {
$('input').iCheck({
checkboxClass: 'icheckbox_square-blue',
radioClass: 'iradio_square-blue',
increaseArea: '20%' /* optional */
</script>
</body>
</html>
smithdunn123
Also the above was with a manually tweaked connection file to use mysqli_connect(), however, the generated code gives me mysql_pconnect() from the server behaviours panel when defining a connection when inserting a recordset.
Should the MySQLi server behaviour not be using mysql_pconnect??
If I use the auto-generated code I get this error when trying to load the login page.
Fatal error: Uncaught Error: Call to undefined function mysql_pconnect() in C:\xampp\htdocs\Connections\mbf.php:11 Stack trace: #0 C:\xampp\htdocs\index.php(1): require_once() #1 {main} thrown in C:\xampp\htdocs\Connections\mbf.php on line 11
You are using the old Server Authentication server behaviors instead of the new MySQLi ones. That is why you are getting the errors about using the old mysql connections on a php7 site.
smithdunn123
This code is generated by the mysqli server behaviours I have just bought from you.
The extension includes the mySQLi and the old mySQL versions of login. It looks like you applied the older one. Make sure you go to webassist->MySQLi->Authentication
Then it will include the correct code.
