Vulnerability on "view order" button: need a first-aid solution
Thread begun 3/13/2018 3:18 am by rikaG_510 | Last modified 3/13/2018 11:01 am by Ray Borduin | 1371 views | 1 replies |
rikaG_510
Hello,
I got below report from the site security checker app.
Using the GET HTTP method, SiteLock found that :
+ The following resources may be vulnerable to arbitrary command execution (time based) :
+ The 'RCUK_View_100' parameter of the /parts/100_rack.php CGI :
/parts/100_rack.php??RCUK_View_100=View%20ordersx%20%7C%7C%20ping%20-n%2
03%20127.0.0.1%20%26
-------- output --------
It seems “View Cart” button function is vulnerable. I know asking this does not solve the whole issue but is there anything I can do to make it less vulnerable?
I attached the file.
Thank you so much for your help.
Rika
You have lots of forms on your page with:
action="<?php echo $_SERVER["PHP_SELF"]; ?><?php echo (isset($_SERVER["QUERY_STRING"]) && $_SERVER["QUERY_STRING"] != "")?"?".$_SERVER["QUERY_STRING"]:""; ?>"
update all of them to:
action=""
That will solve the problem.
